matt0941 wrote:Not for a Z32 MAFS. In addition, why do you want to go with 72lb injectors? This number seems a bit large for the application (T3/T4), not saying you are wrong in doing so just curious.
The 72lb injectors are not too large at all. With the 50lb injectors I max out at 14PSI with a T3/T4 (95% injector duty cycle).
With the 72lb injectors it maxes out at 20PSI.
96lb injectors will merely reach the full potential of a large trim T3/T4.
If you want to squeeze more fuel through the 50lb and 72lb (even the 96lb
Then, you can use your S-AFC to fine tune the MAF voltage (and therefore the fuel supply) in order to get the proper A/F mixture (i recommend doing it on a dyno for safety)
