sapix @ RHIT »
https://forums.nicoclub.com/sapix-rhit-u1947.html
Thu Dec 12, 2002 5:40 pm
well, at 4 psi your not going to notice a lot of difference. You should be fine on the stock injectors, but not positive. A BOV doesn't regulate pressure, it helps extend the life of the turbo by preventing compressor surge. At 4 psi you don't need one. To regulate the boost you'll either need a boost controller, or get the spring in the internal (assuming its internal) wastegate change. If you want to go cheap, get a manual boost controller. I'd say get a Walbro fuel pump, these seem to be the best units you can get, I think the fuel pump from a 300zx TT will also fit. I've heard the MAF can let you hit something like 260 hp or there abouts.
But even with all this, you'll still need a way to get more fuel to the engine. Your going to have to get something to control it. Fuel control is the most important aspect of tuning.
