Yep, this is correct.Darius wrote:NO. Exactly the opposite of what he just said.
The supply line comes from the fuel filter and goes to the line that feeds the rearward end of the fuel rail. The fuel then passes through the fuel rail to the fuel pressure regulator. Whatever is bled past the FPR goes to the return line.
that is 96+ only i think.Darius wrote:To add to Kamin's comment, don't mix it up with the gas tank EVAP line that is near the two fuel lines. That line also runs to the fuel tank, but carries fuel vapors from the tank to the intake tract on the KA to be burnt for air pollution purposes and as I've found, to prevent your interior from smelling like gas.
