fuel line question
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
pejsa s-13
Car: 91 HardBody, 85 720
so my truck sputters alot and iv been searching for a solution and found this
"What i found is that these 720's use a return fuel line with no restriction.. so what you get is ZERO fuel pressure to the carb. I have no idea how these things run at all, unless you have a vane/rotor fuel pump that spits out 7psi or so. What I ended up doing is putting a Purolator ($20) adjustable fuel regulator on the return line, and set it so that I have 3.5psi at all times. It helps to T off a pressure gauge so you can watch it under hood. Anywhoo, my power fade problems are gone."
and use a fpr like this onehttp://images.google.com/imgre...PTwAw
is this true/possible/reasonable/tested?
seang
Car: Ford Fiesta ST
That sounds feasable. I don't see how they had no pressure to begin with. Weird?
pejsa s-13
so i tried this and please please please tell me im not retarded and did not put this on the delivery line?
and what the heck are these?
PEZi
pejsa s-13 wrote:please tell me im not retarded and did not put this on the delivery line?
not really sure... i'll be doing a carb conversion soon tho so i'll be looking into it.... you should be able to tell by following it up to the carb
i believe the name for them is 'vacuum switching valves'... i may be wrong on the name but they suck... they f*** with air and fuel somehow... if you look at the pic you showed... you'll notice they have electric lines to them as well... you can rid of these parts but what you'll have to do is cut and loop the electrical lines in a 'plug and play' fashion until you get it running right... i honestly believe this process is why my hitachi isn't as much of a piece of s*** as many are...
my carb has some of the same characteristics as some people's webers... it runs a little too rich between 1,000RPM-1,700RPM or so... then starts pulling pretty hard... i also have a feeling that my spark plugs are what allow for it to be rich because they burn the hell out of the fuel
now to answer the question i believe you aiming at 'are they smog required?' i don't know... but it would probably be harder to pass for sure
pejsa s-13
thank you kindly sir that was almost perfect
pejsa s-13
P.S. it was the delivery line
PEZi
lol... nice
pejsa s-13
yea thats what got my truck runnin all crappy hahaha
so now it runs excelent
additional question for you pezi
my truck has the rear diff that doesnt have the removable cover and today i was playin around and did a burnout in my drive way and both tires got some action. is the rear diff on these LSD?
jtbenfie
Car: 1983 Nissan 720 King Cab 4x4. NAPSZ 2.0 5spd
pejsa s-13 wrote:my truck has the rear diff that doesnt have the removable cover and today i was playin around and did a burnout in my drive way and both tires got some action. is the rear diff on these LSD?
Not necessarily. Even an open differential can spin both tires, espically on flat level, even traction surfaces. The only sure fire way to tell is pull the differential and check out whats in there.
there may be a way to tell what came in the truck originally from the vin or another sticker, but im not sure what it would be
PEZi
jtbenfie wrote: The only sure fire way to tell is pull the differential and check out whats in there.
too much work lol
you most likely don't... both tires can get traction with an open diff... the easiest way to tell it to jack the rear end up... spin one tire forward... if the other side spins forward you have some sort of LSD... if it spins backwards its open diff
jtbenfie
I agree, you most likely don't....
only problem i have with jacking up the rear and spinning the tries is that if it is a limited slip and the clutches are worn from age(all our trucks have some age) they will probably spin opposite like an open diff.
You could always just linclon lock it
wesradford
Car: 1984 Datsun/Nissan 720 Pickup with 2.4L 4cyl
Just curious...how did the fuel pressure regulator work out? Did you see much (any) difference in performance?
Return to “Datsun 720”
