sebazztard »
https://forums.nicoclub.com/sebazztard-u58647.html
Sun Sep 13, 2009 4:42 pm
so i hastily put up my car for sale because of a fuel leak which i determined to be a tank issue, and on the s14 is a pain in the nuts to take out, and im going through some s***, and i dont have any extra time to drop the tank and fix/replace. sounds crazy but i need a daily driver, im in a super pinch.
symptoms:
GAS EVERYWHERE.
my gauge reads near empty which has always been accurate. the leak is coming from above the seam when you look at it from under the car, on the passenger side. ive always thought that when you turn the key off, the fuel would stop, but perhaps being under pressure i may have a broken rubber line somewhere, hidden from a visual inspection. will a line leak for hours, literally.. or do you think my tank is garbage? it just doesnt make sense to me. im starting to think my line is bad now, but is it possible to leak for that long with the car turned off? its a steady drip, then slowly stops.
i understand that is pressurized, and my cap is off as well when i did these tests.
clifnotes... leaking from above seam in tank, gauge reads empty.
