Fuel leak from fuel pressure regulator and engine is hard to start hot or cold
digger12
Car: 1989 240sx
Hello:
My son has a 1989 240sx. His first car. It is stock and is a bit rough. He took it to highschool shop class and I have spent a lot of time fixing up what they did there.
I am not a mechanic. It was running very rough and I put in new plugs, wires, cap, rotor. I replaced this injectors with a fairly new set from a wreck. It now runs on all 4 cyclinders and runs very well.
There remain two problems however.
1. It is very hard to start, but after cranking for say up to 20 - 30 seconds, even in sequences of 3 or 4, 8 second intervals, it fires up. When running it runs smooth.
2. I noticed yesterday the fuel pressure regulator was wet with gasoline around the edge after the car had been running in the garage. I replaced the pressure regulator with one from a wreck. It also gets wet around the edges after the car is shut down. Today I opened the hood and noticed it still was getting a bit of gasoline around the fuel pressure regulator, even though it had not run for 15 hours.
When I remove the gas cap, there is pressure in the tank.
I am at a loss on how to stop this gas from leaking around the pressure regulator.
Does anyone have any suggestions on what to look at next or advice on what keeps the pressure in the line and yet it is so hard to start (hot or cold)?
Thanks, and have a great day.
