Fuel leak down test?
vancouverbc
Car: 1991 240sx
I lose about 20 psi in 30 seconds. Is this oK? If I pinch fuel line between fuel filter and gauge, I dont lose the pressure so I know the check valve or canister or gas tank is leaking. Not sure if this abnormal.
Q45tech
Are you saving that the 34 psi reduces to 20-14 psi then stablizes or continues to drop to zero? How long does it take to go to zero?
vancouverbc
Car: 1991 240sx
It stabalizes around 20 psi.
Q45tech
If it stays 20 psi for 24 hours that's pretty normal. Shouldn't create any cranking problems.................20psi ~~= 77% of running idle flow [at 34 psi] ecu is designed to function with this psi.
vancouverbc
Car: 1991 240sx
Thanks very much.
