Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Sat Dec 30, 2006 10:03 am
You've got it all wrong buddy. You failed the emissions test for HC, right? That isn't a fuel leak, with the exception of a torn injector o-ring. You are running too rich. This is most probably caused on the 240sx by a bad ground to the MAFS. Try installing a new external ground to it, many people have found that this clears up an overly rich condition. Particularly on older cars, because of deterioration of the quality of the grounds.
BTW, you don't have a 240zx (no such thing), you have a 240sx.
EDIT: Check your oil for fuel. If you have a torn injector o-ring, it would cause you a pressure loss like you described, while causing an overly rich condition. It will cause your cyl walls to wash down with fuel, and eventually your oil will be thinned from fuel.
