fuel issues
jason29
ok so my car wasnt starting and turns out the fuel pump wasnt coming( no reading at the fpr nor was there high amounts of fuel coming out of the main line when cranked on) i by passed the hardwire kit i have for my deatchwerks pump and sent 12volts straight to the pump and pump comes on and the fpr is reading just below 50. car still doesnt start. thoughts???? is there something ecu related or something else that would prevent this short term fix from not working?
gnubberlang
Car: 1995 240SX SR20DET
2004 Frontier 4x4 Crew Cab 5-Speed
Hi. Have you got spark and are the injectors opening? I'm guessing one of those are missing, probably the injectors. Not to say they're bad - I'd assume it has something to do with the fuel pump not being powered.
jason29
yea ive figured out pin 36 isnt getting 12v from the ignition switch
