Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Sat Sep 17, 2005 4:30 pm
39 PSI at idle at the regulator is normal. Figure this at 0 " Hg, your regulator will run at 43 PSI. So, since it references manifold pressure at 1:1, if you have 8" Hg of vaccum, that (if it could be thought of as pressure, would be -4 PSI), would make a regulated pressure of 39 PSI. When you say it is cutting out, what RPM does it do it at? Are you sure it is a fuel problem? FOR GOD'S SAKE, FIX THAT LEAK BEFORE SOMEONE'S FIXING YOU WITH SKIN GRAFTS! That said, we need more info, from a guy who is killing himself on a fuel issue, I have taken quite an education lately on diagnosis of fuel problems, and am happy to help, but we NEED MORE INFO.
