CotBU »
https://forums.nicoclub.com/cotbu-u5960.html
Wed Sep 05, 2007 12:39 am
Most likely no, it's an installer error. Did you lube the o-rings before installing? did you check for leaks before trying to start the car?you removed you old injectors correct... did the new o-rings fit snug on the injectors or were they loose?were the injectors seated correctly, they usually snap into place.
Quote »alright so before I wasn't getting fuel to the engine, it was getting to the fuel rail but not through the injectors... So my fuel pump was working, so I checked all my wiring everything looked good tried a second ecu, still nothing though... The only thing I could think of was either bad injectors or injector plugs, so tonight I just put in new plugs and injectors,[/quote] You need to verify that the injectors are work, whether it be a wiring test or firing test (noidlight) if its a wiring problem not ecu problem where in the wiring is the problem... do the injectors work now? If not then when you fix the leak it's still not going to start.
Anyway are they sidefeed injectors or what? becuase they will be surrounde by fuel in the rail, so if fuel is pouring out the to of all the injectors and the injectors are working it will still fire, assuming air compression and spark.
that's why after you install the injectors you disconnect the injector harness, cas, ignitor or whatever else that would cause a fire inside the engine or outside the engine.
edited for content. -TA
