blackhole1 »
https://forums.nicoclub.com/blackhole1-u51099.html
Sat Jul 11, 2009 3:54 am
I searched and did not get much help, I have been throwing parts at my car for over a year now and still no cure. I have a s14 sr rebuilt stock bottom end, rebuilt head HKS stg2 264 cams, brian crower springs and retainers, sard 550cc injectors, z32maf, lph255 fuel pump, enthalpy tune.
this is the issue right now my car idles like crap, timing is good, plugs are good and gaped at .030 running 12psi of boost. checked for vac leaks none that I can find, I did noticed when I fill gas tank the car runs ok, but when the gauge unit goes down to half a tak of gas it runs rough idle is irratic and lot of vibration wants to stall, after the gauge passes to a 1/4 of a tanks it runs great, this is a little weird.
I replaced the sock in the fuel pump, replaced all fuel lines in the tank to 100psi fuel hose, got rid of but connectors for fuel pump harness, {soildered} and used heat shrink for wires, placed fuel pump back in the tank where it is supposed to sit, still no luck
what is up I am ready to part this car-out had nothing but problems fom day one and it almost has all new parts, the turbo is almost out but that wouldn't cause it to do this right? sorry for being long winded just want to be detailed for the best help.
