fuel is pumping, starter is working, battery is working. but car wont start?
91nissantwo40sx
Ok my car was just running a couple days ago and suddenly it stopped running. A mechanic told me that it could be my fuel filter so i went to the store and bought a new fuel filter. The old fuel filter was really dirty and i tryed blowing through it and no air was coming out. So i replaced my fuel filter and starter the same day. So i try starting the car and all i get is the sound of the starter cranking but car wont start?
I took out the top hose of the fuel filter and fuel is going through the filter no problem.
Why is my car not starting then?
Felipe
Car: abcdefghijklm nopqrstuvwxyz `1234567890-= ~!@#$%^&*()_+
do you have spark?
91nissantwo40sx
drifters2it_sideways wrote:do you have spark?
I dont know. how do i find out? PLEASE!! I NEED IT RuNNING ASAP!!! ;( ;(
Felipe
well first check your spark plugs to see if there fugly and what not.
also check your timming.
91nissantwo40sx
timing? im pretty sure the timing is right. my car was running good before already. I DONT KNOW WHY THIS IS HAPPENING TO ME!!!!
Felipe
its happening to you because you have 16 year old car. shtt happends.
alot of peolpe had said that and found out that it was the timming. it dosent hurt to check.
edgartheace
Car: 1993 240sx, 1992 300zx RIP, 1993 300zx 2+2, 1993 Infinti J30t
Start simple. check power to your ECU, power relays (ECCS, EGI) , Spark, fuel,
91nissantwo40sx
edgartheace wrote:Start simple. check power to your ECU, power relays (ECCS, EGI) , Spark, fuel,
Im so sorry im such a noob at this. How do i know if any of these things are working properly? well actually u dont have to answer the question. I am sick of this car. It just keeps giving me problems.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Check for spark at the coil output. If that's OK, check each cylinder for spark by pulling each plug wire, one at a time, and plugging in a spare plug into the wire, then lay the plug on top of the valve cover and look for a spark.
240sxLover
Car: 1996 Nissan 240sx
Did you check your alternator because the same thing is happening to my 96 240
