Fuel inlet and outlet
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
Bart
Gday guys,/Mettler need to use your brain, Im about to complete the fuel line on my VH41 but want to make sure which fuel pipe on the motor is the inlet and out let, i will be using an Edelbrock fuel reg which requires pricey fittings so i want to get it right the first time is why im asking you guys.Thanks guysMy fuel tank, this fuel tank was welded by a chap in Dapto near Wollongong NSW, company name is extreme turbo manifolds i think. Good bloke and good price if anyone is interested.
Turbo trial fit
Turbo trial fit
Turbo mnifold tacked together
Modified by Bart at 4:42 AM 11/11/2007
T45
Car: King Kong powered Z32
That is one crazy build! And the fuel line nearest the front of the engine should be the inlet, but don't hold me to it.
RichZilla
Car: Y34 Nissan Gloria VQ30DET 12PSi & 20" rims
Be careful when you weld all those pipes together. I can see the possibility of some serious warpage there.
Bart
Thanks guys, if anyone else can confirm the inlet fuel pipe it would be great.Warpage on the manifolds? The tubing is 3mm wall steam pipe, and it will be fillit welded i believe the term is as all the butts have an angle ground into them
Modified by Bart at 4:48 AM 11/11/2007
Bart
just realised richzilla is in sydney lolJust to let our US friends know this car weighs 2314.854 lb's so power to weight ratio is the key here. If i can get 700hp i will be a happy boy.
Bart
Actually while i got you guys attention, (i hope) is there an after market alloy/billett fuel rail with -8 fittings? Id love to buy a couple as it saves time rather than making them
RichZilla
Ahh, fair enough. It looked like you were using normal mild steel bends. That's why I thought it all might warp.
What car is that? A Torana?
doctorchee
Car: BMW 318IS
hi
i am running Vh41DE twin turbo also. in the progress.
you look like having serious fuel system set up.
just like to share, i change the fuel system to 2inlets, 2 outlets instead. as i plan to upgarde my injectors, i do not want the last injectors (cyclinder) to suffer as the fuel supply is dry after many of injectors in front.
in addition, i run a balancer before fuel inlet so that if 1 fuel pump failed, i still have 1 to support for a while.
hope this helps.
Bart
Sure is an LJ Torana
Return to “VH45DE / VK45DE / VK56DE Forum”
