Fuel injectors
bboybuya
Anyone know where to get good but inexpensive fuel injectors?
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
What motor do you have? If you've got the KA24E I've got a set of 370cc (same size as the SR) that would drop right in if that's what your looking for.
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
My brother has a '93 Altima and he had an injector go out recently. I took him to the local import boneyard and he pulled a good injector from a wrecked Altima for $20. Works perfectly.
If you go this route, be sure you are able to return it if it is faulty. A little risk involved, but if you get good injectors it'll be worth it.
Daunttless
Or if you aren't looking to upgrade, you can send it to one of the companies that cleans and rebuilds injectors, its only like 8 dollars per injector to get it cleaned, rebuilt and flow tested. : )
maxpsi
Movingviolation240 wrote:What motor do you have? If you've got the KA24E I've got a set of 370cc (same size as the SR) that would drop right in if that's what your looking for.
I think you mean ka24de not ka24e. I got my 370cc injectors from an Sr20det also. They work fine in my ka24det. Ka24e injectors are top fed only. The sr20det injectors are side fed just like the ka24de and later model vg30detts.
