Fuel Injectors
Yht988_180sx
Hi does anyone know if the 1990 RX-7 550cc injectors (high impendence) will directly into the CA18DET with no modifications required except for the plugs on the injectors?
Any help would be great! thanks
Daunttless
Yes, they will.
Yht988_180sx
Daunttless wrote:Yes, they will.
Sorry I'm just a little concerned about swapping the injectors cuz I measured the 370's and they have about 2-3 ohms and the 550's have about 13.5-14.0 ohms.
So I can directly replace 370's with the 550's without removing the dropping resistor from the system. I just want to make sure before I go ahead and change them. I really appreciate the help! Thanks! =)
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
the dropping resistor is easy to pull out, just pull it and stick a 3in lenghth of wire in it's place. Nobody I've talked to has had a problem with that when they've done the swap in australia, and I've never heard anybody say anything about pulling the resistor. I think you can just re-adjust everything and it will work fine when you re-do your management for the injectors.
PaulOrlando, FL
PSif you want a different answer, I have an upgraded AFM, an HKS AFR and a set of 440cc injectors for sale $250
Movingviolation240
how did the swap of the 550cc injectors turn out? please give me any info you can. i would like to do that to my ca also. thank you, Victor
Yht988_180sx
It was pretty much a straight bolt on, except I had to modify the plugs with rx-7 ones. First, I had to get my injectors rebuilt and cleaned. I'm using the Apexi S-AFC to control them along with the Z32 MAF.
