Fuel Injectors
Kevin.A
Car: Nissan 300zx RB20 swapped
I think i have a bad fuel injector, my car sounds like a sti with just a muffler, so i pulled my sparkplugs, and 5 of them are black, 1 is white.
So that cyl is running lean, so i replaced the plugs and swapped in a known good coilpack. It didn't fix it.
So i'm looking at replacing the injectors, used injectors from RawBrokerage are $120 plus i would have to get them cleaned and flowtested plus o-rings and seals, it's the same price(almost) as the 440cc injectors also from RawBrokerage.
I have a Haltech ECU. So my questions is, if i put the 440cc in, will i be able to drive the car without getting it tuned?
(i don't want to drive it forever, just a month or two)
Kevin Anthony
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Assuming this is a RB20?
We do sell used injectors individually. As well as new o-rings and seals.
The 440's will need drop resistors (but since you have a Haltech you can easily change the settings in the software to run them). A tune will be needed though.
RRRRB
Car: 98 RB powered S14
might as well swap the suspect injector to another cylinder to verify issue..
