Fuel injectors
ZOMG.SR20
Car: 1990 s13
i have a feeling my fuel injectors are bad but i figured id ask for advice these are the symptoms
stalling between 1000 - 2000rpm ( pain at stop lights and when taking off )after that runs fine idles rough plugs are new wires new fuel filters newair filtrs new MAF checks out and no check engine light oil just changed
any suggestions again i have a feeliing they're the injectors but i dont know
spindrift187
was the cap/rotor replaced? I had a car do the exact same thing till I replaced em.
ZOMG.SR20
Car: 1990 s13
the whole dizzy or just the rotor and cap and could it be possible to have the cap on wrong
ZOMG.SR20
Car: 1990 s13
Edit the car only does this when warm not first start
louisb323
Car: '92 240 Fastback
Sound's like it could be egr valve.
spindrift187
I mean just the cap/rotor, I don't believe its possible to put the cap on wrong but it is possible to have the ignition timing off by the dizzy(wouldn't be your issue though).
ZOMG.SR20
Car: 1990 s13
ordered the cap/rotor in the mail hope it shows up and see if that solves it
480sx
Car: 1996 Pearl White 240sx
Easy way to test for a stuck injector/leaky fuel o-ring. Get your car at an idle. Pull each injector plug off one by one. What your looking for is a injector plug that when you pull it, it doesnt effect the idle. Or it doesnt effect it as much as the others did.
You can do the same thing with your spark plugs. Pull them one by one and do the same test. If you find one that doesnt effect idle as much as the others, that means your wire or plug is bad.
SHIFTVAX
Car: 2006 Nissan Altima SE-R/92 N issan 240 SX
Mine did the same stuff turned out to be a dead injector because I had new plugs and wires too.
Diaper
Car: 1992 Nissan 240SX
Mine did that about a week ago. I took the fuel rail off another KA and it runs great
ZOMG.SR20
Car: 1990 s13
=] cap and rotor went in 10 times better than b4 runs beautiful
the old rotor was completly corroded lol
