rockinthefans »
https://forums.nicoclub.com/rockinthefans-u55908.html
Thu Jul 10, 2008 1:24 pm
Do you mean the injector itself knocking or the motor? Injectors make a constant ticking sound as the needle valve inside opens and closes. Now if one does not make a sound that means it isn't working because the needle is stuck in either the open or closed position. If one is leaking you would need to pressure test the fuel system and see if pressure bleeds off. O-rings are a big problem with injectors. What kind of problems exactly are you having?
