Post by john ardito » https://forums.nicoclub.com/john-ardito-u82329.html Sat Dec 01, 2007 8:08 am
Post by Q45tech » https://forums.nicoclub.com/q45tech-u112.html Sat Dec 01, 2007 8:23 am
Post by goody90q45 » https://forums.nicoclub.com/goody90q45-u31761.html Sat Dec 01, 2007 8:44 am
If you're measuring directly on the injector top it means you have a dead injector. If you're measuring at the connector you have either a dead injector or a bad injector harness. Do you have injector symptoms- rough idle? What's the reading on the other fuel injectors? 10.0-14.0?john ardito wrote:I get no ohm reading on number 5 injector....Does this mean it could be a electrical problem not the injector?
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
