fuel injectors
robyc
Car: Cars, cars, and, um, oh ya, CARS!!
for those with a sr, what fuel injectors are you using?
pampadori
Car: 91 Nissan 240SX coupe
msd 50lbs. going to 72 lbs in my other 240sx. shaun
BuudWeizErr
370's
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
nothin special about stock buud ;)
BTW, does it require fuel management tuning if i want to run 480cc or posibly 550cc injectors besides a fuel pressure reg. and fuel pump???
sorry for the thread jack! :icesangel
BuudWeizErr
J-Spec Tuner wrote:nothin special about stock buud ;)
Says you. I know a lot of slower cars that would kill for some 370's.. hehehe. ;) :pface
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Quote »if i want to run 480cc or posibly 550cc injectors besides a fuel pressure reg. and fuel pump???[/quote]
You would need some sort of piggy back fuel computer or programmable ecu.
robyc
good one buud. :D
pampadori
NISSAN says you can use injectors upto 15% larger without any mods. shaun
burgy240
Car: 2000 Q45 Ann. Edition Blk on Blk
15%....thats to much math....hehehe anyway, I'm running stock for now but as soon as I upgrade turbo's I'll be using TTsupra injectors.
hokiruu
Car: 2012 INFINITI M37X Platinum Graphite
'95 240sx/s14 SR20DET (in 2000) SOLD
I just bought a Tomei fuel pump, rated to 500hp for my upcoming SR swap. According to Sam at JSpec, its a direct replacement. Do you think this will work on the stock SR ECU program or will I need a retune? Oh, and sorry for the threat jack. To make it a little relevant, would it be healthy to run 550cc injectors on an otherwise stock SR? Obviously using some sort of fuel management.
pampadori
your fuel pump will be fine without any other mods. i believe its similiar to the walbro (holly) fp. the regulator takes care of returning the extra fuel to the tank. with proper fuel management, any injector is ok to use. 550 injectors usually don't need anything, but larger and they usually need a resistor on each injector or the ecu driver gets hotter and fries in some cases. not to mention it won't run well.shaun
NeedCAforS13
Car: CA swapped S13 coupe
15% over 370cc is 425.5cc, so i would imagine you could use skyline 444cc injectors w/o any problems..right?
Sean
*whoops i forgot to mention i have a ca18det, not an sr20..just looked at the heading...oh well
RHDS14
Does anyone know if the SR injectors are high or low impedence. I am swapping to the 444 GTR injectors and need to know this.
robyc
so what does the stock fuel pump flow? the walbro, and similar replacements, flow around 255 lt/hr.
would it be good to have different fuel rail for 550cc injectors?
what fuel rails are available?
Onizuka
arnt GTR injectors top feed??
achilles0t
if you have the proper gauges to moniter your car you wont need a new fuel rail till you hit at least 450. my buddy has 555cc inj with a safc /car runs sweet
themadscientist
J-Spec Tuner wrote:arnt GTR injectors top feed??
yes
robyc
achilles0t, are you meaning 450 hp in last post for updating fuel rail?
Onizuka
themadscientist wrote:yes
Well then how in the hell are you supposed to use skyline 444cc injectors on the SR20 without modification?
60dash1
sr injectors are high impediance saturated type.
Silviagirl79
Car: I love Silvias, Skylines, Soul Calibur II, and GT3
J-Spec Tuner wrote:Well then how in the hell are you supposed to use skyline 444cc injectors on the SR20 without modification?
you're right you cant use top feed injectors, since the RWD Sr20det uses only side feed.
I H8 UR DSM
just get a different fuel rail
60dash1
I H8 UR DSM wrote:just get a different fuel rail
exactly.
Onizuka
you make it sound so easy....
hokiruu
I'm reviving an old thread here, sorry of that bothers anyone. In order to run 550cc injectors, what do you actully have to do with an S-AFC or S AFR? I mean how do you use it to make larger injectors run? just add the fuel increase percentage as much as possible? I have an s14 SR, the turbo is good to about 14psi, but the injectors are only good to 10 on this turbo (so I'm told) so naturally I want bigger injectors, but $500 is a big chunk of change for a retuned ECU. Is trial and error with 550's and one of the aforemetioned piggyback fuel controllers really dangerous? I'd be a little worried about damging the engine while trying to get the 550's to work. Or is it really not that hard?
I H8 UR DSM
It would be more of the opposite...the larger injectors flow more, therefor you would lean out the afc, not increase the fuel flow, ya know what i mean?
Dont do a retune, either buy a tuned ecu from japan, but i would stick w/ the SAFC. affordable and good
I H8 UR DSM
oh, and we dont mind!!! u searched!
hokiruu
Thanks Jesse. Do you have any connections for used reprogrammed ECU's? Sam at Jspec and Japandy on ebay used to have them pretty often, but seems they harder to come by lately. So you favor the SAFC over SAFR in this case? Why? I would love to have a Power FC Dejetro, but I don't know how to use one and neiter does anyone else around me, plus i really can't afford one. I'm just looking for a poor boy's way to safely squeeze a few more psi out of my turbo, as 10psi is def. NOT the top of its efficiency.
vangj
Car: Cars, Sports
I have question for you guys... I currently have stock turbo, FMIC, Profec B, stock injectors, stock fuel pump, and other general exhaust stuff. I wanted to upgrade to 555cc's, a Walbro fuel pump, and an SAFC. I've been reading this posting and people have different opinions, but will the 555cc's work fine with my setup. I have a Mine's tuned ECU that I bought from J-Spec. They told me that it was made for the stock setup, but I don't know exactly. Will these items work fine together??
Another question, My car has idle problems. If I unplugg the o2 sensor, it idles a little better. It idles really bad when it's plugged in. Will those items help me out also with my idling problem?
MojoMan
Car: working on cars and women
You need to verify the program on the daughter board of the ecu and make sure it is compatible with your set up such as maf. What maf is it programmed for? Have you checked your maf to make sure its good. Are your injectors good? Maybe bad o-rings??? There are too many things it could be. You need to take it to someone thats familiar with the motor. I believe in another post you said the o2 sensor was new and from an 87 300zx. Are your plugs fowling out? What do they look like? Are they gaped right? Apearently its running rich. I know how it is to drive without the o2 plugged up. It runs off of the base map on the ecu by running in open loop. How is your fuel pressure and how much?
