J-z, I have to disagree here. Your ECU controls the flow of fuel out of the injectors. The fuel pressure reg, is just that, it regulates the pressure in the line. Your ECU changes the pulse width/duration the injector is open increasing your fuel. The longer the injector is open, well you get the point. That's why you have to get a tune, because a stock ECU will simply not be able to add enough fuel for the correct mixture.j-z wrote:afc doesnt tune fuel pressure! using a high pressure pump will change base fuel pressure. now in the situation i am using 560s (averaged flow of all 4) deatschwerks and a safc i HAVE to use an adjustable fpr. fuel pressure changes the amount of fuel flowed out of the injectors. without the afpr id be running too rich because the afc can only compensate for so much. i dont know what the 52lbs equate to in cc, but i know it will be close to the afc limit of compensating. in his case it would be wise to run one and anyone else running 550s with a afc. he def has to run one with a top feed rail.
whaaaaat????? what exactly are you disagreeing with? we need the afpr to keep the fuel pressure at the stock pressure to keep from running to rich. from what i got out of what you said is that fuel pressure doesnt change the amount of fuel flowed? if so, thats totally WRONG. they make something exactly what you were talking about instead of going with a tuned ecu. its called a fmu and they raise fuel pressure in different ratios to increase fuel flowed out of the injectors. my deatschwerks flow chart says that at 50 psi my injectors flow an equivalent to 600cc as opposed to 560cc at the stock 43.5 psi. and no its not more reliable to use a fmu as opposed to a ecu tune as you cant tune out specific points on the rev band where needed. fmu just increases fuel pressure as boost increases. it works, but using a safc is way better than that. have no idea where that post cam from ?.yes you can use ss braided lines, but its not needed. if you want the bling then you have to use AN fittings if youre gonna go with the SS line.jr_ss wrote:J-z, I have to disagree here. Your ECU controls the flow of fuel out of the injectors. The fuel pressure reg, is just that, it regulates the pressure in the line. Your ECU changes the pulse width/duration the injector is open increasing your fuel. The longer the injector is open, well you get the point. That's why you have to get a tune, because a stock ECU will simply not be able to add enough fuel for the correct mixture. The SAFC just modifies what the ECU see's, leaning or richening up where needed by the imputs you select on the unit. If a regulator were to increase fuel flowed, everyone would be doing the regulator and not getting an ECU tune, not to mention it would be way cheaper to have a reliable turbo'd Ka.
I'm disagreeing with the concept that fpr does not increase fuel flow. They simply put the fuel pressure where you need it. I understand that at a certain fuel pressure injectors flow a certain amount but, it's not actually the regulator itself that is flowing the fuel. The ECU uses the injectors to increase the amount of fuel injected into the cylinders at a given fp by way of the pulse width. The pulse width is what changes the major amount of fuel injected into the cylinder. A long pulse (injector opened) the more fuel. When the fuel pressure is at a higher than stock rate, sure more fuel will flow, but it's not the fpr that does this....j-z wrote:whaaaaat????? what exactly are you disagreeing with? we need the afpr to keep the fuel pressure at the stock pressure to keep from running to rich. from what i got out of what you said is that fuel pressure doesnt change the amount of fuel flowed? if so, thats totally WRONG. they make something exactly what you were talking about instead of going with a tuned ecu. its called a fmu and they raise fuel pressure in different ratios to increase fuel flowed out of the injectors. my deatschwerks flow chart says that at 50 psi my injectors flow an equivalent to 600cc as opposed to 560cc at the stock 43.5 psi. and no its not more reliable to use a fmu as opposed to a ecu tune as you cant tune out specific points on the rev band where needed. fmu just increases fuel pressure as boost increases. it works, but using a safc is way better than that. have no idea where that post cam from ?.yes you can use ss braided lines, but its not needed. if you want the bling then you have to use AN fittings if youre gonna go with the SS line.
edit: my previous post may also have helped the arguement to get you two on the same pagejr_ss wrote:
I'm disagreeing with the concept that fpr does not increase fuel flow. They simply put the fuel pressure where you need it. yes, where you need it for desired flow
I understand that at a certain fuel pressure injectors flow a certain amount but, it's not actually the regulator itself that is flowing the fuel. huh?
The ECU uses the injectors to increase the amount of fuel injected into the cylinders at a given fp by way of the pulse width. correct!
The pulse width is what changes the major amount of fuel injected into the cylinder.correct again!
A long pulse (injector opened) the more fuel. almost there!!!!
When the fuel pressure is at a higher than stock rate, sure more fuel will flow, but it's not the fpr that does this....ooooh...fail. the fpr DOES force more fuel through the injector per given pulsewidth. explain how a fmu works then... maybe ur trying to say its not the fpr that raises fuel pressure to make more fuel flow? thats true. but fp can be raised manually;afpr (or by boost;FMU) through the fpr to make more fuel flow per given pulsewidth.
It was just a statement but, I believe we weren't arguing, just debating. Either way it's all sorted out...j-z wrote:thanks for making that clear as day post egan. im with you on every single thing you pointed out especially on the 'HUH' part of what he wrote. ive been on the correct page from the start. i just dont even know why he made his first post as i said nothing for him to start this. plain and simple what i was saying from my first post is that change in fuel pressure will change amount of fuel flowed. not once did i say anything about pulse width, so i have no idea where that one got pulled from.
