FUEL INJECTORS OR FUEL PUMP???
FRbeliever
Car: S13 PS13 RPS13 SILVIA 180SX 200SX 240SX SILEIGHTY ONE-VIA
My 91 240sx chokes when I accelerate on flat ground.
During long corners, the problem worsen.
During constant uphill the problem is the worst, completely losing the throttle response.
IS IT THE FUELT INJECTORS OR THE FUEL PUMP??? THANKS!!
Nismochick240
Car: 95 240sx- BONE STOCK.. for now
neither
injectors= skipping (car shaking really bad at idle)pump= car would not start (will if beat on gas tank)
if you are loosing throttle respone, you might have a tps going bad
FRbeliever
Throttle Position Sensor huh... But why the fuel cuts worsen when the gravity is forced to one side? Does the gravity force affect the tps?
Modified by FRbeliever at 1:29 PM 12/11/2005
Nismochick240
mmm not sure have you checked all your fuel componets? filter? hoses? it might be closed. if not you may have a bad tps
