dilipdeka »
https://forums.nicoclub.com/dilipdeka-u24271.html
Sat Jan 08, 2005 12:16 pm
My Nissan Murano (2003 model) ran great for 40,000 miles. On 12/20/04, while driving on a highway in Houston, Texas, at 70 mph, it suddenly surged forward and the engine died. On restarting the engine would not hold. The car was towed to the nearest Nissan dealer, Robbins Nissan. The mechanic replaced the fuel pump but that did not solve the problem. Then he checked fuel pressure at the injectors that was found to be at recommended 50 psi. But fuel was not going through the injectors (all six). He tried to clean the injectors by applying gasoline with cleaner directly to the fuel rail. He even increased the fuel pressure to 70 psi. This effort did not produce any result. Then he used a set of injectors from another Murano and found that the engine runs. He blames bad gasoline in the tank of my car to be the culprit and Nissan technical advisers agree with him.However I do not agree with them and think there is some inherent problem with the injectors or the EFC (Electronic Fuel Control) system is malfunctioning intermittently. 1. There was no indication prior to the engine shutting down that injectors were getting clogged. The engine was running smoothly like in a new car. Fuel economy number was running at 18 mpg.2. The fuel tank was at ¼ full. The car ran fine on the same tank of gas till the incident.3. The dealer hinted there could have been some contaminant like sugar added to the tank. This does not seem possible since the Murano fuel tank has a lock on it. Also the car is parked in a garage at night.4. We use the same gas stations to fill gas tanks in three other cars in the family (Jeep Wrangler, Jeep Grand Cherokee and a Ford Cobra) and none of them has had a problem with fuel injectors.Has any Nissan car owner had a problem with fuel injectors? I’d greatly appreciate any input I can get.Thanks,Dilip DekaHouston Texas
