Fuel Injectors for rb25det?
TachPHD
what are the possible fuel injectors that can be used on the rb25det engine?
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Is this a serious question?
With a different fuel rail or the stock one, either top or side feeds above 370cc, whether they're low impedance or high impedance, that can be made to support either with resistors.
TachPHD
ok thank you, sorry about that, i'm still a learner
wawazat8402
Car: 89 Sil80- RB25DET
They are just a Nissan purple top injector.
Tictakman
ok, not sure if u want to modify ur stock ones or not but heres the skinny...
the rb25det comes with stock 370cc (pretty sure) side fed high impedence injectors.
u can run top fed low impedence injectors by getting a top fed fuel rail and getting resistors to change the impedence to high. u can get 10 ohm resistors at radio shack. one resistor per injector is what i ran.
Zak
wawazat8402
Or you could order from Deatschwerks. I believe they are a sponsor of NICO. Good prices with a great reputation for reliability.
TachPHD
thanks alot you guys
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I'm looking at ordering some top feed injectors to support 500 hp. FYI I'm assuming 700cc will do the trick. Does low resistence correspond to low impedence? And if the injectors are listed as low impedence, do they all have the same amount of resistance so that a 10 ohm resistor to each will keep the ECU happy? Sorry for the newb questions but I'm just getting to this point in my project and haven't really looked into it too far.
