First, you need to read throught the posts about VH45DE fuel injectors, particularly with regard to ethanol (which DFW has in its fuel) and the replacement injectors thread by Heath whose trialis ongoing.
If you have to pull the plenum to get to the injectors, it is a good time to replace those old hoses and clean the pelnum and lower runners so your cream puff will run as smooth as butter and not expire in a puff of steam from a broken hose.
Under plenum hose and gaskets from IoS
http://www.infinitpartsusa.com
Call them with your VIN.
