DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Wed Dec 06, 2017 2:57 pm
Sorry OP for not checking back quickly.
As mentioned the Z1 link is good and covers much of the issue, except the always-on electrical state of the earlier model Z32's injectors.
This wiring issue can be corrected with a how-to on twinturbo.net, in addition to what's been covered here. This issue was fixed by Nissan for '95 and up Z's, and will ensure no electrolysis issues as well.
Full disclosure- doing the wiring mod makes the ECU unable to store problem codes. It will display them as normal, but can't save them for reference by you/it later.
The solution to reading a code should you do the mod, is to note a code presenting and stop/park safely, DO NOT KEY THE CAR ALL THE WAY OFF but just key back to ON and proceed to read your code as normal. The ECU will always display a code when it should, as normal, just storing it is the problem for DIY/reporting use and therefore the solution.
