grantfc »
https://forums.nicoclub.com/grantfc-u59451.html
Tue Jul 24, 2007 4:17 am
I have not replaced the under plenum hoses going to when i do the injectors, cahin guides replaced almost 2 years ago. Have not replaced the KS senors, they ohmed at .563 & .578. I am just wandering about the big difference in ohm readings on the injectors. Is that normal when some go bad? I used the search on ohming the injectors and it says 10.0 to 14.0, call me a dumb redneck but only 2 show to be in that range....are all others bad #'s 1,2,3,5,6,& 7 are 4 & 8 the only ones ok or as long as it is close to the 10.0-14.0 reading?
