Seedlessone »
https://forums.nicoclub.com/seedlessone-u79768.html
Mon Oct 26, 2009 5:33 am
SR20DET S13 into 89 S13 Hatch. DIY wiring, then sent off to Wiring Specialties to sort it out and make sure it's right. Harness came back good.
I've had this swap ongoing for about the past year, and still not running. I'm hoping someone here can help. We're to the point now where we have spark, timing correct, fuel pump primes and pressurizes, but we have no pulse at the injectors, thus not spraying.
Just did a continuity check from the ECU, and it seems pretty jacked up. From what I understand, we should have continuity from the ECU to each injector independently from pins 102, 103, 110, and 112, for the pulse, then the other side is ground. What we got instead was continuity from pin 112 (Injector No. 4 drive output) to injector 4 on both sides, and then also at other injectors. Sounds to me like a wiring fault.
Where from here. Help.
