So you're saying the pintle caps dont fit into the holes? Why not try and swap the ones off the OEM injectors on there?DjLiquid wrote:yeah, something like that but the injectors dont fit in the holes on the plenum with their heatshields on. would it be okay to use them without the shields?
I have always thought that the stock purple top ones from a 88' turbo II were high impedance. Have you check the injector with a ohmmeter to make sure? On the link you posted, it says the Denso replacement 550's used purple tops for both their low and high impedance injectors. Wouldn't hurt to check.DjLiquid wrote:according to the guys on here (http://www.rx7club.com/showthread.php?p=6757270) i have these:
1988 13B Turbo, high square offset, 550cc, purple, 195500-1370 (part number)
lol.. i have the tan onesmikesim wrote:you bought high impedance injectors dude.
1988 RX-7 195500-1370 Saturated 550cc Purple Top
Saturated means HIGH impedance.
What you needed are the Tan tops. I've seen and held tan tops, but the guy was asking for too much.
1986-87 RX-7 195500-1370 Peak and Hold 550cc Tan Top
here's the site i use for determining RX-7 injectors:
http://www.robietherobot.com/s...e.htm
ok.. ill stop confusing everyone right now. I have the tan top ones. If i said that i owned purple ones, im sorry. the ones I have are tan. im 100% sure. They are low impendance. I checked with an ohm meter. I will also post pics latermikesim wrote:you bought high impedance injectors dude.
