Sned wrote:Cost:Consult II reading, FreeRemanufactured GB OE replacement injector, $93 (their cost)Install of #2, $40 (I know I could have done it myself but am glad I didn't. Gave them some biz and William showed me the trick to do it. WD 40, place and twist in.)Consult II reading again, Free
It sounds like you found a good mechanic. He changed the easy injector for you but the replacement of #6 FI is going to involve removing the plenum. As good as your shop is they're still going to have to charge 6-8 hours labor at $100+/hr to stay afloat.
If money's tight and your mechanic buddy is worth his salt the two of you should have no problem removing the plenum. It's not rocket science. Since your Q came from the other side of the Rockies be prepared for some hose replacement while the intake is off. Between now and then do lots of reading in the Q forums and print up some articles so you're prepared. Lots of people have done it with no issues, minimal hose replacement and posted some great tips to make it easier for the next member to take on the challenge.
"Remanufactured" means they've been sent to Deatschwerks (or equivalent) and been sonically cleaned, ohm tested and flow tested. If you've sent an entire fuel rail with 8 injectors they'll put them back in the rail with new o-rings and then pressure check the rail for leaks. Other than a new pintle cap nothing has been replaced or disassembled.
It's always a crap shoot buying used injectors but removing the plenum and getting it back together in 3 hours gives you something to brag about. Plan ahead and buy a fuel rail with injectors from another member or ebay ($100-$150), send them to Deatschwerks for cleaning ($15/ea) and you'll be set to go plus have a few to sell.
