onecrazyfoo4u »
https://forums.nicoclub.com/onecrazyfoo4u-u42462.html
Sat Feb 09, 2008 4:34 pm
I have a pretty basic setup, so I still run the stock 370cc injectors on my redtop. Lately I've been getting really bad gas mileage, like 20 mpg or less. I always get around 25. I'm thinking I might have a bad injector, or they might be leaking.
When I pulled them out of the rail and turned the key to 'on', so the pump was priming, there's wasn't any leaks or drips whatsoever. This is how it should be correct? Then if I try cranking the car, should the injectors spray a nice continuous mist, or should they drip?
Is there any other way to diagnose an injector to see if they're working properly? Any other way to test it would be awesome, I need to get my good gas mileage again!
