lino wrote:
1) Can you please tell me how to check my DVM witha 10 ohm resistor?
2) Also, is there a time that is better to check, for example when the car is warm or cold?
3) What kind of issues will be noticeable when the resistance starts to rise?
4) Is 6 hard to get to?
1) Put the probes of the DVM, in the ohms resistance setting, on the leads of the 10 ohm resistor. It should read very close to 10.0.
2) In my experience the resistance rises in a warm engine as much as 0.8 ohms. For me, the readings are more meaningful from a cold engine.
3) With one dead injector I didn't notice any change until I replaced it and then the acceleration, throttle response and gas mileage was definately improved. Others may have had differnt experiences.
4) You can replace #1, #2 and #8 injectors without touching the plenum. For all the others you will have to loosen and shift, or completely remove the plenum to get to them.
Removing the plenum is not as hard as we make it sound, you just have to stay organized so you can remember how to get everything back together. Go to Q45.org for step-by-step instructions. There's many other things (hoses, KS, harnesses) that could be replaced once you've got the plenum off but I'll let others preach to you about that. Good luck.
