blubottlemax »
https://forums.nicoclub.com/blubottlemax-u3386.html
Fri Feb 18, 2005 2:14 pm
I pulled all the spark plugs, and #1 was soaked in fuel. I pulled that injector, and the O-rings looked good. Re-installed it, and same problem. Next, I pulled the #1 & #2 injectors and swapped them. Idle is a lot better, and no fuel on either spark plug and running. All plugs are extremely sooted, I'm presuming from the 370's. I had it set at -27%, but I think I'm going to go to -28 or even -29% to lean it out some. I have an Innovative Wideband, but the bung hasn't been welded in yet to my downpipe, which also is not installed. This is my daily driver, so I'm installing the turbo a little bit at a timel. Plan was to pull the oil pan today and get the return bung welded on, but this has taken up so much of my time today... bleh. I swear, Helicopters are easier to work on than cars sometimes... lol
