NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Wed Sep 10, 2003 12:58 pm
check out the ones in the car first, see how they are doing. BTW when you have the injectors in the position i told ya, I forgot to mention they will spray once when the key is cycled from the off position to the run position. It will only give a quick burst. then they will spray while you crank the engine. but once the key is relesed from start position to run position they should stop spraying. if any of them do not spray or if they continue to spray when the key is on i would recommend replacing it. I am not familier with the place mentioned in this thread that cleans them. I do know a cleaning proceedure. but it requires the car to be running.
