Jesda »
https://forums.nicoclub.com/jesda-u7038.html
Thu Jun 08, 2006 6:02 pm
#7 is a pain.
You have to remove the plenum (and all hoses attached to it) to get to the injector. You'll end up replace the brittle and old hoses while you're there.
Once the plenum is off, removal is the easy part. You use an impact screwdriver to remove the screws and then pliers to twist the injector out, making sure to remove both o-rings.
Then, you put new o-rings on the new injector, lube the o-rings with grease or oil, and insert it. Then, you reattach the metal cap and two screws. Preferably, you replace the screws with ones that have non-philips heads.
More details are available in older threads. "Tangalora" has some pictures in her threads.
