I have a '91 with a bad #3 fuel injector. I checked the solenoid resistance and it was open.
Whats the easiest (if there is such a thing) way to change it out? I removed the 2 screws and the cap and tried to pull it through the rail with no luck. It rotates fairly easily though. Do you have to pull the entire rail off to replace a single injector?
Too many sheep and not enough revolutionaries.......
