Fuel injector removal
tonis56
Car: 04 Titan Crewcab
Took off my fuel rail last night and after removing the caps on top of the injectors, it seems as if the injectors are really not wanting to come out of the rail. How did you get them out with out damaging them.
Tony-
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
I used a really sturdy knife to get in between the injector lip and fuel rail, then came in with a screwdriver to leverege them out the rest of the way. Very carefully of course. What ever method you use, dont try and press them out from the injector tip, you'll damage them.
tonis56
thank you for the detaled description. I will try this tonight. I was gonna go with pushing on the tip, but I didn't think that would be too good.
tony
ca18det_boy
I used some WD40 to loosen up the seals....then took a thin screwdriver and slowly pryed them out.
TheSparo
yea use 2 mini flatheads and pry them out on each side.. and i mean use leverage when i say pry... don't hammer them in there and pry them out
SCOOTER240
Car: 1990 240sx sr20 black top
soak the injectors in wd40-turn the injectors arround in the ports-that will help to loosen the seal-do not use a screwdriver or a knife-tha could damage the sealing surfaces and ruin your fuel rail-just be patient with them and they will come out-also be sure to check that both seals come completely out and the ports are clean of old seal
wildacexxx
Car: 2002 Q45 nav sport
how about liquid wrench? i hear that melts styrofoam why not seals
tonis56
it definatley melts styrofoam. I dont know what it would do to the seals.
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
i found myself in the same situation last time i switched injectors, it seemed way easier to bolt the rail back down and pull the inj with visegrips. i just put a rag over the teeth and gently pulled them out. put a little wd40 on the seals before reinstalling and it wont be any problem next time.
tonis56
Hey, I have another question since we are on the topic of injectors. What injectors are you all using? Brand and flow rate. Im lookin at some of the deatschwerks injectors and I just wanted some feedback from people that have used them.
tony-
srpowered240sx
stock 370's, purple tops.
