DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Tue Jun 24, 2003 4:25 pm
No hot tank! There are several types of cleaning devices, including hot tanks, jet washers, and parts washers. A hot tank will probably discolor the aluminum. A parts washer uses a much more gentle solvent at a lower temp and is fine for aluminum. Plug the small holes in the plenum, turn it upside down, and then just set it in the washer and fill it with warm solvent. A jet washer is not damaging either, but probably not too effective on such a cavernous part.
No way to remove the injector without damage that I can figure out, unless you remove the rail. Then you can just push them out (carefully) from the bottom-side. But a few scratches in the plastic body probably won't hurt much. Just don't pull up on the metal stem! To remove from above, grab the outer body with some grips, rotate to break the seal set, and just turn it back and forth while pulling up. Empty out the fuel rail first, or you will fill the cylinder with fuel when you remove the injector.
The temp sensor near the water pump can be replaced with a short 19mm (or 17mm?) socket and a wobble ratchet extension. I've done it, yet I don't know if that's the ECU or the dash sensor. I just figured I'd replace all sensors at once.
