Fuel injector reliability
Saabjock
Car: 2003 Nissan Pathfinder
How leak prone are the fuel injectors in the 2003 Nissan Pathfinder with VQ35 engine?
I suspect I have one leaking and if they are, I may consider a different alternative.
Upgrayedd
Car: 2002 Nissan Pathfinder LE RWD
202k miles on my '02 and as far as I know it still has the original injectors. What makes you think you have a leaky injector? What issues are you experiencing?
jscricca
Car: 03 Pathfinder LE
I thought I had a bad injector but it turned out to be the fuel pressure regulator. After hours of research I never found anyone who replaced an injector.
Throw in some Techron quarterly and I think they will last forever.
Wrierblock20
Car: 1998 Nissan Pathfinder 2WD
Replaced my #2 fuel injector at 205,000 miles it started leaking into cyl #2 causing misfire. Its more likely to be clogged or seal wears and it leaks into the cylinder. I would run Royal Purple MAX injector cleaner in 10gal of gas should clean them up nicely, my symptoms were P0300 muti misfire I ran 7gal of gas and full bottle of royal purple max injector cleaner that cleared up and got p0302 cylander 2 misfire but my symptoms were hard starts poor acceleration and hesitation at high speeds flashing CEL when it got real bad
