DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Tue May 06, 2003 9:08 pm
1) It really depends on how much your time and labor are worth relative to the cost of the parts, plus your estimate as to the risk of not doing them. Your injectors are probably the same as the Q's in cost...about $140 each. In the 4+ years and 40k miles I've owned my Q, I've only twice had an injector fail on me, one of them just a few months ago. And I live in a so-called bad gasoline (RFG) state. No other injectors replaced according to the service history. I'm certain that the 2nd time you pull the plenum will be tons easier than the first. I keep a spare injector in the trunk, along with my tools.
2) Injectors fail in 2 distinct ways--either a circuit failure (the code you got) or by clogging. Cleaning will help the 2nd mode, but I don't know if clean injectors last longer or not. Certainly if there's any physical damage to an injector, such as worn insulation or a cracked wire, no amount of cleaning will help at all.
3) I *think* very little relationship within the 10-14 ohm spec. At 23.2 ohms, I'm not sure what happens...maybe decreased firing time? Perhaps Q45tech can quantify any relationship. Again, clogging has no effect on resistance.
4) In regard to your #2 injector, verify that it is the injector that is high and not just the harness. I know of one Q's harness that is high on 2 injectors, but the injectors are fine when ohmed directly. Definitely a cheaper and slightly less labor-intensive fix!Though it won't fix a bad injector, a cleaning is not a bad idea. I just flushed my fuel rail Monday night and my car runs real smooth now. There was an infrequent but noticeable slight roughness at idle before, and that's completely disappeared. Looking forward to doing a fogger intake cleaning soon as well.
