fuel injector question?
djpotential
Car: Cars, computers, music, CAPOEIRA, Breaking
Ok, I popped the hood and found that i have leaking injectors. I am not thta mechanically enclined, but i have searched the topic, and can remove them and all. My question is this.. The plugs that connect into the fuel injectors-then into all the wires(harness I guess).. are all starting to crack. When i touched the one where it was cracked the idle dropped dramatically, then went back up after i let it go. They are all pretty much the same way. first of all..
1. what are these plug/wires ( technical name)2. they seem to be go into the harness( do i have to replace the whole harness?3. help........
thanks
i have a pic of what i am talking about, but when i post it (115x100) it tells me its to big and to post only (300x300)..O K
s13sr20chris
what kind of car? if its a nissan you can get replacement injector connectors. are you comfortable with cutting wires and soldering or butte connectoring back together? you can go to a nissan dealer and the parts counter person will prob blow you off so check with pinnacle nissan or courtesy nissan online parts dept. they can get you the connectors with a little pigtail that makes it an easy splice. if you do one, do them all. if you want you can get them aftermarket too. i have had good luck with the aftermarket as i believe they are the exact same part(in this case) sold in a different box. beck arnley worldparts sells jecs-unisia oe connectors. try that, its way better than a whole harness. well the harness would actually be better but more work and money.
djpotential
oh sorry, I have a 1990 240sx.....i will have spliced wires before, but i have never delt with any from and engine area, just speaks and stufff. w hat are the websites for these places?
s13sr20chris
http://www.nissanparts.org/the aftermarket parts you would have to find locally from a beck arnley dealer.
djpotential
yeha i checked all the nissan sites, but none seem to have the injector connecters (w/tail). I emailed them and i am waiting also. thanks for the info!
If anyone has the link to them that would be great, since i am not finding them... much appreciated
s13sr20chris
http://www.bap-geon.com/main.htmli know they can get them for a 300zx; maybe they can get them for a 240sx as well. the store is right down the street from me. see if they will sell them to you over the phone or something. if not, you can send me money and i will get them for you.
djpotential
sweet! after work today i will cal them.. thanks man!
