fuel injector question
scottgas
Car: 1996 Nissan 300ZX N/A steel roof
Can a fuel injector both OHM out correctly AND have voltage but NOT work?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Yes, if the plunger is stuck mechanically. If it clicks when powered, then no. Keep in mind that almost all injectors are powered constantly and triggered by the ECU grounding them. So just having 12V power doesn't mean it's a complete circuit. You should test by popping the connector and applying external power and ground across the terminals. If it clicks then it's working.
scottgas
I pulled the CAS and spun it by hand and I can hear all the injectors clicking. I have a long thread about the issues I've been dealing with and pulling my hair our. It is my Weird Injector Thread.
