USMCgetsome »
https://forums.nicoclub.com/usmcgetsome-u15451.html
Thu Nov 25, 2010 10:42 am
what other car or engine is compatible with our fuel injector? I plan on heading down to my local salvage yard and if i can't find any 240sx what other engine or nissan chasis has our same type of injectors?
my issue with the injector is that it is not firing. I checked for voltage at the plug and it's 10.5vdc and plugged and unplugged the connector and checked to see if it would change the engine note. Nothing happened. I check for spark and it's there and firing.
My #1 cylinder isn't firing so currently the engine is running on 3cylinders only.
thanks for reading and happy thanksgiving!
red top injectors side feed ka24de 270cc low impedance or high impedance?
