Fuel injector Question
240DrpTop
Car: 1993 Nissan 240SX vert sold
2006 Nissan Xterra
1982 Nissan 280ZX
1984 Nissan 300ZX
I replaced two fuel injectors today. My question is why were they so hard to remove,and does anybody have a solution for removing them easily. Thanks in advance!
94_240sx
Car: 94_240SX
Been there done that. Right way is tapping it from the back after you take off the fuel rail. But, most people don't do that. You can spray a lot of WD-40 and use this kind of plier(on the left) to pull it out. There are holes on both sides of injector. I just use a channel lock and pull it out. Most of the time, injector is completely destroyed, but who cares.
110octane
Car: VQ35DE powered 240SX Convertible *SOLD*
SR20DET powered S14
Ditto. I had the same problem.
94_240sx speaks the truth! I found the same to be the best option.
B-Boy DuB-L
well i find that the best way with the least amount of damage is to have 2 screw drivers. pry one in under the connector and pry it with just enough leverage to lift it up then take another screw driver or something thin and strong and slide it to the other side of injector with the slit u created
Hijacker
Car: '92 240sx Convertible
'94 F-150
It's easy to pull them out with anything so long as you're careful. I've used vice grips before. I put a prybar down to give me a fulcrum point for the vice grips.
240DrpTop
2006 Nissan Xterra
1982 Nissan 280ZX
1984 Nissan 300ZX
Thanks!
MXMOVRDV
Car: 94 240sx vert 66 mousestang
Glad to see some stuff going on with injector's. I have one dying. #3. I will probably replace all of them. I have noticed a drop in performance also. Anybody know good place to get injector's? checked out deatschwerks.com and they are a good $ for set. $ locally and they cost more.
B-Boy DuB-L
deatschwerks.com is prolly your best bet for stock injectors. If you try and go to the dealer for one injector it is around $179 + tax. At the website its only $200 for all 4
Trae
Car: 87 RX7 TII, 93 240sx Vert
A few of my friends sent theirs to be serviced. They came back looking almost new. If the coils not bad on the solenoid in the injector this would be my option
http://www.witchhunter.com/injectorserv1.php4
roger!7
Car: 1994 Nissan 240 SX convertible
How do you know if it is the injector or possible wiring problem. Is there a way to check the voltage?
240DrpTop
2006 Nissan Xterra
1982 Nissan 280ZX
1984 Nissan 300ZX
Question answered in your injector thread. Do an ohlm test. 10-15 ohlms across the injector.
roger!7
Where can I get the pliers?
240DrpTop
2006 Nissan Xterra
1982 Nissan 280ZX
1984 Nissan 300ZX
I would try your local NAPA,or similar auto parts store. Sears has a large selection of tools. Or you could try;
http://www1.mscdirect.com/cgi/nnsrhm
240DrpTop
2006 Nissan Xterra
1982 Nissan 280ZX
1984 Nissan 300ZX
B-Boy DuB-L wrote:deatschwerks.com is prolly your best bet for stock injectors. If you try and go to the dealer for one injector it is around $179 + tax. At the website its only $200 for all 4
92.00ea. at Auto Zone.
