Fuel Injector Question ????
72nismo
Car: 510 / G35 / Murano
If your injectors are dirty would the car idle funny? Or will it only do that at certain times? Any info appreciated. Thanks
RinseCycle
Car: 95 S14 w/ Redtop SR20det (stock)
dirty/clogged injectors can cause issues at idle and load.
check the resistance of the injectors before you go trying anything else, if the resistance for all four is within a few .1 (i believe they should be around 15ohms?) of eachother then you probably have another issue.
72nismo
How do you check the resistance??
