matt trickey »
https://forums.nicoclub.com/matt-trickey-u63745.html
Fri May 04, 2007 4:57 am
I tried the Nissan forum but it didn't help. I have a 91 Infinity G20 with a 2.0 Liter. It was running rough and I had a mechanic look at it. He said the fuel injector was bad in the 4th position. He and I both listened to it with a long screwdriver (the old can and string trick) and we both agreed that it wasn't pulling its load. I ordered a new one from Auto Zone, put it in and test drove it around the block. It ran great. The next morning I went to start it up and gas started coming out of the exhaust. When I took the injector back off I noticed the o ring (the small one by the pintle cap) was deformed like it was melting. I put a different o ring on and they keep melting. Also, that cylinder is dead too. The mechanic did a compression test and all was okay so there isn't a hole in the piston. I checked to see if the wire was sending a spark and it is but that cylinder keeps flooding out. I lubricated the o rings and pushed the injector straight down. It seems like it is a problem with the injector but I don't have the tools or the know-how to check if the injector even works. All I know is it did work briefly and now it doesn't.Does anyone know what course of action I could take now? Besides paying an arm and a leg at the shop.Thanks, Matt
