NeedCAforS13 »
https://forums.nicoclub.com/needcafors13-u4234.html
Fri Jul 16, 2004 3:34 pm
if you can see the wires (or my injectors had different colored tape on them) here is the order they go... they all have grey plugs IIRC:
Injector 1: Wire 1: white/black Wire 2: whiteInjector 2: Wire 1: yellow/black Wire 2: yellowInjector 3: Wire 1: green/black Wire 2: greenInjector 4: Wire 1: blue/black Wire 2: blue
the one with the black wire is the ground, the colored one is the ecu signal.
the green plug goes to your green idle air control cylinder (can't remember the name right now... I want to say IIAC valve)
the red plug goes to that red temp sensor.
Sean
