Where is this thing located? My chk engine light comes on time to time and I'll try cleaning the connectors too.nuQ wrote: you should check the connection of the MAF (mass air flow sensor). mine did the same thing and i simply unplugged the connection, carefully cleaned up the brass pins, then used dialectic grease on the connectors and plugged it back up. all was fine
MAF is mounted on the side of the airbox.Peterofdevon wrote:Where is this thing located? My chk engine light comes on time to time and I'll try cleaning the connectors too.
Thanks!!!
Peter
