fuel injector issues ka24e rough idle
redeonx
Car: 1989 nissan 240sx
im have trouble with my 89 240xs . it has been idlen kinda bad., but it starts idlen at 800 rpms normal then drops to 200 rpms only when i come to a stop or when its parked . mim going to clean out the plugs on the fule injectors today they dont look to good in there, any help on wat i should use on them to clean it would be a big help.
it has a ka24e rebuild motor i put in it. it went in easy.
and im have som exhaust probles i keep breaken the rubber hangers and suggestions on wat i should do ? or how many rubber hangers should be holden up the exhaust. ty for ur time i hope some one can help me
180fan
Car: 89 fastback
Cleaned the plugs on the injectors? You'll find a green coating on the connectors and a possible loose female end on the harness side. Then give the injectors a good cleaning. Otherwise if they're leaking, replace the 0-rings.
The exhaust problem, sounds more like they've gone brittle and busted on you. Mine are stretched pretty taut and I've got all 3 or 4 of em on. Consider getting some polyurethane exhaust hangers or the solid rubber ones by nismo.
redeonx
wat should i clean the plugs with? and the exhasut only has 2 rubber hangers and tere shout be 3 or 4 but no place to put the rubber hanger. how hard it it to replace the o-rings on injectors?
180fan
Car: 89 fastback
You can get electrical contact cleaner at your autoparts store. Spritz some of that stuff and scrape with a small flathead screw driver. It's a bit tedious but alot cheaper than buying a new injector. Other thing is to check the female plug on the harness. It helps to bend those in very slightly to get a clean contact to the freshly cleaned contacts of the injector.
The injector o-rings are easy to replace. Drain the fuel system of pressure and pop out the injectors. When you replace the o-rings, put a thin layer of vaseline on it to keep it from shredding or bunching when pushing it back into the fuel rail.
There are 2 hangers at the very end of the muffler, almost to the end of the car. There's another one a few feet back from that one. Then there should be another one towards the back end of the piping.
redeonx
ok i cleaned out some of the plugs and didnt have time to scrap them out, but im ganna do it tomarrow. when i clean them out by just sprayen them off it seem to run some wat better but i still need to scrap them out. i use parts cleaner they sayed it sould work the same . they were all out of the wire cleaner spray. and for the exhaust i looked at there are 2 at the very backj end of the muffle but the passenger side metal hange looked like it broke off. and the drive side looks fine. and i found one right be for the muffle near the a arm's or wat ever u call them. thank u for helpen me out.
